Question for folks running 69mm pulleys on roush setup
stanger1
KS
2013 Shelby GT500-Sold, 2017 Roush RS3
I only have experience with the 2.3 TVS, but i was thinking that if you have a 69mm on a 2.3 vs a 69mm on the 2.65, the 2.65 would see a significantly higher pressure in boost as it is a larger rotor pack and moving more air/fuel.
Since I believe both are being mentioned here.
A 69mm on the 2.3 would be equal to a 75mm ish on the 2.65??
I have just an 80 on my 2017 RS3, Roush Phase 2 and 91 octane needs a little Boostane.
MiDiablo
#JustA4Banger
Spring Hill, FL
www.youtube.com
Josh
2018 Mustang GT PP 400A 10R80 RTR Spec 5 Widebody
Did any of you guys have to clearance your blower to run the smaller pulley? I remember reading somewhere that the snout needed clearanced.
kapiteinlangzaam
Netherlands
5.0 GT Coupe 6MT PP1
The 80mm on my 16 P2 2300TVS sees about 10-12psi, right? Id very interested in dropping a pulley size or two.
Would anyone be kind enough to link to a decent pulley (69 or 75mm). I want to stay 6 rib, not changing the whole setup over to 8.
Would I need a tune amendment from Lund as well, or can the computer self adjust?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
I run a Grip-Tec pulley and make 15-19psi on 6-rib just fine.
When I was running a TVS 2.3L rotor pack, I ran a 72mm and was making 12.5-13psi through LT's. No belt slip either.
kapiteinlangzaam
Netherlands
Do you run 93 or E85?
What sort of WHP are you seeing?
Cory S
Bradford, NH
Cory
Boosted5.2
New Mexico
Julio
2017 Mustang gt350
I want to run a 69mm pulley on my Roush Phase 2 2016 mustang. Stock is a 6 rib pulley and 80mm.
For folks who run 69mm on these 2.3L TVS setups or who know about these setups, are you getting belt slips? Seen folks getting belt slips? If not, what's your setup to avoid belt slip?
Going to an 8 rib belt complete drive system just to be able to run 69mm seems a waste of money. Is 72mm pulley with 100mm idler the smallest pulley I can run with no belt slip?
What size belt did you end up running on this set up?
nnnnnn
C-A
Mustang GT Premium
I honestly haven't had the car back yet since I made this post, however long ago that was. Engine has been with engine builder since earlier this year. I did end up purchasing a 69mm pulley with a 100mm idler which I now have laying around.
Boosted5.2
New Mexico
Julio
2017 Mustang gt350
Dang it, trying to figure out if just running a smaller belt will be good with a 69mm, trying to help a buddy find out that info. But thanks!
Bioni007
Las Vegas
Mustang 2015 5.0
So the stock supercharger belt is K060815
with a 90mm idler and 69mm pulley
but I run a K060802 with a 90mm idler and 69mm pulley
Boosted5.2
New Mexico
Julio
2017 Mustang gt350
Awesome, so for a stage 2 roush kit that idler should be a 90 mm right? If it hasn’t been changed anyway
nnnnnn
C-A
Mustang GT Premium
Late reply but yes it would be 90mm by default from the stage 2 kit.
