Angrey
- Jun 21, 2020
- Coral Gables
- 2016 GT350
So I bought a rivnut tool with nuts that you see on Amazon, ebay, etc.
I'm installing a set of canards and needed it for that, but wanted it for future stuff too.
The canards arrived and I had already purchased the black anodized M5 bolts. The canards came with what's called a slotted nut, rather than the shorter, typical ribbed nuts that come with most rivnut tools.
Well, the proper pilot hole for an M5 is about 1/4", so I measured and drilled. Getting ready to use the tool for the first time, the slotted nuts are slightly bigger diameter than the same M5 ribbed nuts. So I enlarged the pilot hole.
I went to compress the first rivet and discovered that the mandrel tip is not long enough to get a bite on the slotted nut threads. However, it was too late to go back to the shorter rib nuts because the pilot hole was now too big. Well shit.
I went searching the ends of the internet to find a longer M5 mandrel. After exhausting my search, I came across a set of the manual rivnut tools and after receiving them, they're what I should have purchased in the first place.
Not only do they store in a much smaller footprint, the mandrel tips are long enough to compress the larger style nut offerings. They can be used with a ratchet or a power tool for infinite "stroke" length (as the inferior tool calls it and has to be preset with limitations).
The manual set also can be used in much more confined spaces (like under a car, inside an engine bay, etc. The plier style giant tool needs basically a free and clear space at least 3 feet wide and several feet away from the rivet location (for the tool, you and enough distance to get proper leverage).
Additionally, there's less worry about if you're compressing it at an off angle.
All in all the manual tools are just a better, more useful and slightly cheaper tool. Skip the giant bolt cutter looking device and get the manuals instead.
