..:: ProCharger Tune Update 06-01-15::..
Status
Not open for further replies.
15GTPP
El Paso
2019 GT
My car is currently being tuned so ill have results shortly.
**For everyone with 3.73's, check your axle ratio when it asks you to modify your tune. Mine was set on 3.31's.
bew
Phoenix
Black 2015 GT PP
Mines writing too. Ugh I didn't modify the tune file though for my 3.73s
Thanks for the heads up. Went back and modified and retuned
15GTPP
El Paso
2019 GT
I now know what 500+hp feels like :headbang: I do have one problem though. The car is idling between 1100-1500. Not sure if it's because I changed the gear ratio or if it's something with the tune but I'm going to send procharger a datalog and I'm sure they will take care of it.
Also have a check engine light with code p0507. Going to look into it.
bew
Phoenix
Black 2015 GT PP
I still feel like there's some slight stutter, but it's much better now. My idle is the same, right at 1100. Does it take some time to 'relearn' ?
Edit: idle just dropped back down to 750-800
EDIT: back up to 1100
argile2000
Tacoma Wa
2015 Black GT PP
I am getting the same. Slight stutter and high RPM. It triggered the CEL once already.
UGH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
argile2000
Tacoma Wa
2015 Black GT PP
P0507 is the high idle code
bew
Phoenix
Black 2015 GT PP
I have a CEL now too
Rubedog
South Bay CA
2015 PP Magnetic 5.0 Redline Recaro
My idle is fine, no codes but the stutter is still there. :( However, the RPM range of the stutter decreased so the car does run better, but still needs help.
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
I was going to order a HO kit Weds ... but I'm holding off again ... :(
ProChargerTECH
ProChargerTECH
Boostville
2015 Mustang(s)
Interesting, no test cars have a high idle
But that's an easy fix. :)
And the CEL light is just due to the high idle
Sounds like a data log will be in the inbox tomorrow for a member
And then we can send that out.
FYI: the cars follow a 100 stock timing and throttle tables until WOT, anything "pre-wot" is all Ford OEM tuning.
foghat
Calgary
2015 GT w/PP
Pony15
Smog City
Mustang GT 2015
bew
Phoenix
Black 2015 GT PP
I did some data logging tonight and sent them on over to ProCharger.
My current symptoms are the slight stutter/surging at part-throttle and high idle.
Pony15
Smog City
Mustang GT 2015
Does the car run better?
Status
