Mickey3
- Feb 18, 2018
- SW Florida
- Walt
- 2016 GT
Hello all,
I’m currently in the process of installing a Stage II procharger kit on a 2016 GT auto. The issue I’m having (and wondering if anyone else has had this issue), is the supplied idler shaft / spacer for the 8 rib smooth idler pulley does not seem to be the correct one.
The install instructions state that one end of the spacer should fit into the existing engine idler pulley, but the one supplied will not fit under any circumstances.
FWIW, this was an older kit (2016) that had been sitting on the shelf of a speed shop in Ohio, but it was heavily discounted.
I’m sure Procharger will take care of it once I’m able to call on Monday, but I wanted to check with you guys, just to make sure I’m not crazy ....thanx
