ProChargerTECH
- Oct 23, 2014
- Boostville
- 2015 Mustang(s)
My personal car runs 28psi of boost, has for 6 years and has worm clamps.The clamping "force" of a threaded bolt is always greater than a slipping screw system with sheet metal. Why do you think people replace them and then no longer have issues blowing off connections. AMS points out only one aspect. Real life points to a different picture. This will be my 3rd "piped" car and wouldn't use anything other than t-bolt or constant torque t-bolt.
I have never once lost a boost tube because of a clamp. So I will be one to always disagree with the "need" for the Tbolt. (I do run a vband on the throttle body, because it looks "cool")
A proper bead roll, and properly (not over tightened) worm clamp have no issues. The main issue is people over tighten them, and strip them. (or don't actually put them in the correct spot, fully behind the bead roll) The bead roll should be doing the work, not the bolt head.
These 2015's don't run near enough boost to justify hard core clamps.
If a person wants to run them, thats totally cool. But its a personal preference, and not a necessity.
