Procharger squeak sound PLEASE HELP!!!
Deadmau5
Deadmau5
Procharger p1 stage 2
Little elm,tx
15gt
Just during idle
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
I am the same as z06 the lines are cool, but not helpful. If you are tossing belts you are either not tight enough (that's what's she said) or pulley alignment is off. Maybe you have the wrong pulley spacer?
Deadmau5
Deadmau5
Little elm,tx
15gt
But that's the thing it didn't do that before . And and it's had all the same stuff on there that was on There before
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
Did you ever adjust the belt after the first couple hundred miles? Unfortunately, i am a total noob, so initially lined up to the first Mark as per instructions. After a few hundred miles tightened it down a little more.
Deadmau5
Deadmau5
Little elm,tx
15gt
That was done a long time ago vehicle has a few thousand miles already
Tommy V
Brookly park Md
Tommy
How do the idler pulleys when u spin them by hand,also grab each pulley and see if it has any play in it when u try to move it side to side.Should spin with no grumble and have very very little to no play.
ProChargerTECH
Boostville
2015 Mustang(s)
I know this thread says "squeak"
But that video sounds literally nothing like a squeak.
Sounds like you got something dragging on something.
Out of the boat loads of kits out there, never heard anything like that.
I would take your belt off, and start rotating things by hand and see what you got dragging.
Deadmau5
Deadmau5
Little elm,tx
15gt
Yeah I've grabbed everything and nothing seems to have any play and they all seem to spin freely . When I disconnect everything and start the car no sound. Soon as the belt is put back on the noise starts again. Brand new belt BTW
Deadmau5
Deadmau5
Little elm,tx
15gt
Yeah I didn't know how else to describe it... But I'm not the only one with issue ... Another guy I'll post his video up does the exact same thing.
Deadmau5
Deadmau5
Little elm,tx
15gt
Is the idler pulley above the crank supposed to have a very tiny gap behind it. So it's not completely against the factory pulley
ProChargerTECH
Boostville
2015 Mustang(s)
yes, it comes with an idler spacer (you install that during the install)
And it keeps them from touching.
If you flip the one the wrong way, I could see issues happening.
Cause the factory pulley is offset if memory serves correctly.
Deadmau5
Deadmau5
Little elm,tx
15gt
We'll see here's the thing nothing has changed since it was installed... Car had around 5k on it with blower and never made a sound . I recently started getting a grinding sound outta nowhere. Sent the head unit in to procharger they said it was fine. I call and explain but not much help.. upon inspection putting headunit back on I noticed , the bolt that goes Into the tensioner that holds the wheel on was completely backed out against the bracket to where the tensioner wasn't able to flex up and down. Took off and replaced the bolt so tensioner moved normally now but sound still persist. Could that old problem have caused one of the idlers to where out?
Doctor Fishtail
Mexico
Mustang GT
My ProCharger recently started making a very loud squeaking sound sent head unit into ProCharger to be replaced they told me head unit was perfectly fine inspected my entire unit and everything even put on Old pulley and it's still makes this annoying sound there are another few cars in my area with the same issue didn't arrive until after a few thousand miles someone please help if this has been an issue before
Run it. Quit worrying about noises. I am so glad I went the Roush S/C
Deadmau5
Deadmau5
Little elm,tx
15gt
Lol I love my ProCharger but staying to think I should have went vmp ... But from what I'm told they all have issues no matter what blower
Doctor Fishtail
Mexico
Mustang GT
Did I just read that you love your Procharger? You know that means you are slow don't you. :lol: Quit worrying about noises. They all make noises. Just run it.
