SheepDog
6.78" on 15-17What size it the stock one on a 17? Is it 7.1XX" If yes at 7500 Im thinking its like 67000 impeller speed. P1 and P1X done at 65000.
Any time. Happy motoring!So if I have a stock crank pulley at 6.78” and the 3.4” pulley on the p1sc what belt size should I be looking at?
awesome! Thanks for the help!
Yep..you are correct...Impeller speed is 64149 with your setup.6.78" on 15-17
I've always wondered about this issue myself. The path that the procharger outlet tube takes is less than ideal. Part of the blower outlet is blocked by the tube because of the sharp upward turn it has to make. I ordered some silicone pieces/couplers from a local vendor that hopefully I can make a smoother transition to the inlet of the intercooler. If all goes well I will post up the results.Since you guys were talking about the Mak inlet tube for the Procharger. Wondering if there is any solution/improvements to be made to the outlet hose, the one that is collapsed about half was to fit the head unit above the body sheet metal. I know it works the way it is, but can’t help but think since everyone makes it sound like the Mak inlet tube is such an improvement that the outlet has to be making things worse than the Procharger inlet ever did.
Isn’t the p1sc max rpm 62k?Yep..you are correct...Impeller speed is 64149 with your setup.
Please do!I've always wondered about this issue myself. The path that the procharger outlet tube takes is less than ideal. Part of the blower outlet is blocked by the tube because of the sharp upward turn it has to make. I ordered some silicone pieces/couplers from a local vendor that hopefully I can make a smoother transition to the inlet of the intercooler. If all goes well I will post up the results.
