Procharger H.O. e85 700 rwhp goal HELP
Discussion in 'Forced Induction - 5.0L V8 Engine' started by Bmaughan, Oct 4, 2019.
  1. OP
    Bmaughan
    Bmaughan Well-Known Member
    First Name:
    Ben
    Vehicle(s):
    2015 procharged mustang gt
    Sep 26, 2019
    Az
    64
    Here's another question:
    If i'm running low 700whp on E85 with the Sai Li fuel system..will i need BAPs?
    I would think the answer is no, since the kit is rated for quite a bit of power...
    but i've heard that some have had issues with it tapping out sooner than expected.
  2. SolarFlare
    SolarFlare Well-Known Member
    Vehicle(s):
    2015 CO GT
    Aug 24, 2015
    S. Fla
    2,388
    669
    Rating:
    100%
    2   0   0
    No. Not really at 700whp
  3. ahl395
    ahl395 Well-Known Member
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,489
    987
    Rating:
    100%
    1   0   0
    Injecting in the pipe directly after the intercooler, then I have an IAT sensor before the bend to the throttle body.
    For a rouch estimate you can use DevilsOwn's calculator on the left sidebar of their site. It's just an estimate though, so I'd get a size or two above. You can always turn the pump down some. http://www.alcohol-injection.com/en/
  4. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    64
    Quick question regarding the sai li fuel system...
    Would it be a good
    sorry to jump back in the conversation a bit but you mentioned logging both boost and fuel pressure... does the omega box do both??
  5. Jay-rod427
    Jay-rod427 Well-Known Member
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,124
    750
    Rating:
    100%
    3   0   0
    yes. The box itself is the boost sensor,a Nd then a fuel sensor plug into it. Then 1 signal cable to nguage for both.
Loading...
Share This Page
