Problem with line lock
RonnieGT
Canada
Ronnie
2017 Gt
I’ve installed an Airaid CIA and SCTprogrammer but line lock is greyed out. Do I need to get a new tune to enable line lock
Zinc03svt
usa
stang
Did you unplug your advance trac/traction control plug by your airbox by chance? That will kill your line lock.
RonnieGT
Canada
Ronnie
2017 Gt
I’m pretty sure everything is plugged in. If it was unplugged I would have on screen continually correct. Also if I hold traction toggle for 4 seconds it tells me that Advance Trac is off. Been reading some posts, I’m wondering if the car has to be driven and all fluids up to temp, just sitting in my garage now.
TriYellowYote
5800 DA
2017 GT PP
The following conditions must be met to initialize Line Lock:
• The vehicle is on a level surface.
• The engine is running.
• The vehicle is traveling less than 25 mph (40 km/h).
• Selectable Drive Mode is not in wet mode (if equipped).
• There are no AdvanceTrac faults.
The following conditions must be met to engage Line Lock:
• The vehicle is stopped.
• The parking brake is not applied.
• The driver door is closed.
• The transmission is in a forward gear.
• The steering wheel must be in the straight ahead position.
I've also heard the fluids have to be at operating temperature but cannot find that documented anywhere.
