PP1 rears all around + 20mm spacers
Schwerin
Home
2019 Mustang
Wondering if anyone has this setup. The OEM 9.5in rears on all 4 corners + 20MM spacers? How flush is it? I believe that this is the same setup that the FP Racing school uses, or similar to it. They may use 25mm spacers.
1 old racer
Fontana CA
Will
had that set up on my pp1 for over a year with no problems
1 old racer
Fontana CA
Will
Dont forget that you may have to c'bore the rims a little in order to clear the oem lug studs if you are going to use hubcentric bolt on spacers. if you do PM me and I will walk you thru the process, its easier then it sounds. I think the best spacers are the slide on hubcentric with extended studs.
