Post Pix of your S550 with aftermarket wheels and tires
Epe_79
Indiana
Eric
2015 Roush Stage 2, 6.7 Cummins
Been a long wait but I ordered my VMS beadlocks then sent them out to get sand blasted and powder coated.....I think they came out just right!
sbella913
New York
2015 mustang gt pp
looking at buying the same set up, did you buy the wheel and tire package from LMR and if so what tires did you get. i really like the stance and I am surprised the 275 in the rear seems to fill the wheel well thought I would have to go wider.
SEAICE
Seattle
BW
2018 Mustang GT Convertible
Some pics of my new Wheels and tires: Fondmetal STC-191s in silver. 20x9 +38 front and 20x10.5 +45 rear, with 255/35/20 and 305/35/55/20 BF Goodrich g-Force COMP-2 A/S Plus. I’m on stock height and the ride is fine and no rubbing whatsoever on stock alignment/camber. The wheels are from American Muscle and tire sizes are those recommended by American Muscle. Were I to do it again, I’d go with 40 series front tire, I’m sure there’s room. Also, the offset for the 9” fronts could be less, which looked a little too inboard in comparison to the rears which are to me, perfect. As pictured, I added 25mm spacers to the fronts effectively making the offset +13.
compprep
Utica, New York
Jim
19 GT PP1,1986 SVO, 2020 Ridgeline(SOLD!)
19 x 10 +40 ET, Forgestar CF5 in silver. 275/40-19 PS4 all around, with a 5mm spacer in front. The front tire in VERY close to the shock. Stock ride ht until I get all the Steeda parts I have installed.
shogun32
Northern VA
Im thinking of going 10.5 in the back so I have the option to either go with a 305 or a 315
then you want 11's. 305/30 on 10.5 is borderline. 275-305 is the range for 10.5" generally.
ninjacoupe
Patchogue NY
Sam
2018 Mustang gt
what is the width and diameter of the rears. Im thinking of going 10.5 in the back so I have the option to either go with a 305 or a 315
These are weld 71LP7100A80F. 17x10 with a 7.9 back spacing. That picture has the 315/50/17 M/T ET street R tires. You have to run BMR minimum drop drag springs (pictured) or stock springs to clear the height.
Here it is with the 305/45/17 on Ford 1 inch drop “street” springs
it would probably be faster at the track with the 305 being a lighter tire. On the street the taller 315s hook much better for me. I have 3:55 rear gears on A10. If you have the 3:15 rear gears it might be too much of a drop.
bellamor
Colorado
J
2014 Ford Mustang V6
Looking for some wheel ideas for my Stang. I am thinking about getting a two-tone wheel from 4wheelonline, but the wide variety of options left me confused. Which are some of the best brands to take into consideration?
