Piston Sleeves?
Dglaze1980
Charlotte NC
Dustin
2018 Mustang GT Roush Supercharged
I am trying to figure out if I need to do piston sleeves on my 2018 S550 Supercharged Mustang? Sorry new to this forum, sorry if this has already been asked.
On the current motor build:
Manley Rods
Manley Pistons
Arp Head Studs
Cometic Head gaskets
Valve Springs
Block Supports
Drive Shaft
ID1050 Injectors
Rod Bearings
Main Bearings
Blower Cams
Fuel System on e85
Car made 960 rwhp on larger pulley before any of this work was done. I think I am going to be closer to the 1100-1200 rwhp when complete, but I have seen a lot of different opinions on the sleeves.
Any help would be appreciated!
EFI
Masshole central
5.Br0
Well you're going to get even more opinions here, your best bet would be to ask your builder.
Personally I'd be comfortable with stock sleeves under 1000.
Over that I would pay for sleeving.
Timbuck
Australia
Tim
2017 s550 6r80
100% sleeves for that power level. I’m not boosted yet for me it was a piece of mind thing for a relatively small added cost ( considering what you have spent on the car) you know you have a bullet proof set up.
There is lots of benefits of a sleeved motor and not many negatives.
16RPG_Turbo
Houston, TX.
Josh
2016 Ford Mustang GT
I'm shooting for 1,200whp and for the love of everything, I wish I had spent the money and gotten a sleeved block...... The extra money at this point is completely worth it in MY opinion. That way, if you decide to go bigger later you don't have to worry..... I was thinking 1,200 would be plenty, and then my friend rolled up with 2,100 and of course I would now want more....
Manley Rods
Manley Pistons
Arp Head Studs
Valve Springs
Block Supports
Drive Shaft
ID1050 Injectors
Rod Bearings
Main Bearings
Blower Cams
Fuel System on e85
sk47
North Eastern TN
Jeff
Thinking About A Coyote Swap? Here's How Each Generation Compares
Hello; A good read about the four generations of the Coyote.
Hello; Quote rom the link above.
"By 2018, Ford clearly had a winner and rolled out the Coyote V8's third generation, with some significant changes. Revisions include direct injection to supplement the existing port fuel injection, further-massaged cylinder heads, and a small increase in displacement courtesy of spray-in cylinder liners as opposed to traditional steel liners."
My take has been the sprayed in plasma cylinders are too thin to be worked. If the cylinder walls are good then you have the advantage of less weight.
I am not sure but do think some one posted about sleeves for the 2018 & newer blocks but cannot recall if such has been done. If the cylinder walls are damaged, then sleeves may be the only way to fix the block.
I am going by the notion you have a 2018 block.
Dglaze1980
Charlotte NC
Dustin
I appreciate the info from everyone it is not a cheap project to add sleeves, I am being quoted 5k
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Sleeve install itself is around 2200. If you have the ability to have the machine shop assemble the shortblock, and you do the rest some cash will be saved. I'd personally do sleeves over 1000hp.
Timbuck
Australia
Tim
2017 s550 6r80
Im in australia.
But I got my Darton sleeves from Brian crowder in the USA for $1100 usd.
And
Machining and fitment here in Oz was $1324 usd
I just got engine builder to machine and assembled short block and I put together the rest. ( my first coyote build). A lot easier than I expected.
Due to the fact I had one hole down , to get that machined out and replaced with factory sleeve was pretty much about 1/3rd of what it cost to just sleeve the whole engine. So I thought why not chuck a little more at it and have a much much better engine that should live pretty happy at my dream power levels of under 1000…
Over built ?? Yes , my father alway said “over built it and under stress it” Then it will last.
My total complete engine parts and machining list cost $10,000 usd.
