StangTime
- Apr 16, 2019
- Ontario 🇨🇦
- Todd
- 19' GT PP1 Manual
Nice job on the install. Simple yet satisfying.Now, I got so caught up in doing the door speakers, I forgot to take pics. But, I also modified the factory speaker rings to mount the new components into the doors.
I also bought 2 cans of FLEX SEAL CLEAR at Costco for $14, and used 1 can to coat the outer panel of each door with clear rubber to deaden some road noise. Yes, 2 cans for 2 doors (1 can each door, for those mathematically challenged). And I mean the outer panel, not the inner panel. That's where a lot of road noise and vibration gets attenuated from.
Now, on the inner door panel where the speaker mounts, I used some Uxcell 5mm foam to help deaden more sound. I also used Uxcell foam over the rear fender wells, and used some Loctite expanding spray foam in the C-pillars to stop the rattle I had from the right rear C-pillar plastic paneling around the side curtain air bag.
https://www.mustang6g.com/forums/threads/who-still-has-the-c-pillar-rattle-buzz.124656/
The pillar speakers are also a bit of a hiccup. I just pulled the factory tweeters, and I Dremel'd out the inside of the factory mount to make the new tweeters fit. Then, even though they held in place fairly well, I also hot glued them into place to keep them from shifting.
After all was said and done, I now have much less road noise, and much better speakers as a result.
