mustank
I have never done car audio anything before. This was a fun experience.
Parts:
Scosche dash kit
Kenwood DDX9903S head unit
JL Audio HD 700/5 v2 amp
JL Audio C5-650 woofers/tweeters/crossovers
JL Audio PowerWedgeCS112LG-TW3 12" subwoofer
This is my second Scosche unit. The climate control display would not always turn on. This one has been solid.
I made a shelf for the amp on the underside of the rear deck. I used carbon fiber tubes with aluminum rods inside, and a carbon fiber plate on top of plexiglass. There are rubber washer between the amp/plate, bars/plate, and bars/rear deck.
You can see the C5-650 rear woofers in the one amp pic.
Here are the crossovers I added because I needed to use High Pass from the amp and then the "low pass" side of the crossover to the rear woofers.
I put the subwoofer in the spare tire compartment. I also put dynamat down. I cut the stock trunk carpet for the sub and made (poorly) a carbon fiber ring with arches to keep stuff from sliding on top of the sub.
The tweeters don't sit super flush.
I mounted the front crossovers in the footwells.
I also ran the door speaker wires straight through the plastics.
I drilled through the firewall for the amp power cable. I used a self sealing metal grommet. I know there is a rubber plug that can be used, but I just wanted to route straight into the car.
The biggest annoyance for me is the door speakers don't line up with the original door plastic grill mesh.
I used an oscilloscope and tone files from JL audio to set the gains on the amp.
Parts:
Scosche dash kit
