WhiteyDog
WOOF!!!
- Jun 30, 2016
- Manheim, Pa.
Hi guys,
After trading info back and forth with @Roh92cp, @ugstang17, and @Chainsaw, I decided to give my '16 GT perf package with the Roush Ford Racing supercharger some better cooling with phenolic spacers and VMP's H/E. It wasn't that it was suffering from high IATs for the kind of driving I do, but making it run cooler can't hurt. Plus I like to fool with stuff. The MFP 8mm phenolic spacers are sold on VMP's site. They don't come with longer bolts which will be needed for the install, but nothing a run to a hardware store can't fix.
I did NOT need new lower motor mounts to achieve supercharger to hood clearance. I put a clump of clay on top of the supercharger at a few places before the install and closed the hood. The closest spot between them that my clay compressed to was 1-1/8". The phenolic spacers are a little under 3/8" thick, so I have just a little more than 3/4" of clearance to the hood with the spacers installed to hopefully allow for engine movement if/when I really lay into it.
I did NOT need to purchase a new belt. Maybe because I have an 80mm pulley it allowed for the distance the supercharger was raised with the spacers?
I did NOT purchase a new FEAD bracket. After making a call to VMP they stated the original bracket that came with the supercharger can still be used. The top hole that bolts into the lower intake just won't be used since the intake was raised and the four other mounting bolts that are on the bracket would be enough. I will get to test/compare my new cooling mods tomorrow.
