5mm thickhow thick is it, I'll pull my pic from the other thread
edit: if I find more I'll post them I don't remember taking a lot of pix.![]()
Looks like mine is approximately 5mm thick, I believe a 1/4 inch is about ~6mm and I remember putting up a ruler on them and it wasn't even a quarter inch.The MFP ones are exactly similar in design I guess. I have attached pic of ones I received too.
What's the Harrop made of, nylon(plastic)?Looks like mine is approximately 5mm thick, I believe a 1/4 inch is about ~6mm and I remember putting up a ruler on them and it wasn't even a quarter inch.
Phenolics are plastics- I believe it is the same material.What's the Harrop made of, nylon(plastic)?
Mine clears the stock hood fine, but there is more rubbing in the insulation.Whipple Guys(I have a Gen 3). If you use these spacers how do you deal with the belt bracket that bolts to the bottom part of the blower(since the blower will be raised)? Also does it clear the stock hood still?
I will keep you all posted. The Paramount MFP Phenolic Spacers don't come with bolts at all. I asked about it prior to purchase and what Wes with Paramount Speed told me was "No, they are not included with the spacers. Too many different setups to do that with. "Please keep us updated as I have a 16 gt with roush blower and was thinking of doing the upgrade myself. Did the spacers come with longer bolts for installation or do you have to source them yourself? I was also thinking of maybe putting a thermal blanket under the blower to help as well since the blower will be off already.
Mine came with longer bolts and cost a little less back in October 2019 and as for belts, I added 1/2" to each belt corresponding to your pulley size.I will keep you all posted. The Paramount MFP Phenolic Spacers don't come with bolts at all. I asked about it prior to purchase and what Wes with Paramount Speed told me was "No, they are not included with the spacers. Too many different setups to do that with. "
Next weekend, things are getting installed on the car including these spacers. Also you will probably need a longer belt, maybe 3/4 inch longer which can be easily purchased. I'll let the installer decide how long of a belt to purchase. Hood clearance won't be an issue with these spacers and the supercharger from what Paamount told me so no worries there.
