Passenger side pad wearing fast then driver?
firestarter2
NYC
RR G350 Track
I noticed my passenger has worn a lot faster then the drivers side pad. Is this normal? The pad where only used for the track and my local tracks are mainly right corners.
BlkGT3
Hot Spot
13 GT86 Autox, 16 GT350 TP, 06 Civic Si TTD car
Just pulled mine to change and wear was equal on both sides, stock pads.
Peter
firestarter2
firestarter2
NYC
RR G350 Track
Yeah my street pads are even. I will pull and see if the inside is different.
wildcatgoal
@sirboom_photography
TBD
Street and track days, same visible wear on both sides. Are you pulling to a side when braking?
Dspec_S550
Los Angeles
2015 Oxford White Mustang Ecoboost
I wore my left rear pad in about half the time as the right rear. Do you leave the traction/stability control on at the track?
firestarter2
firestarter2
NYC
RR G350 Track
I am in track mode, but I trail brake. I am curious of the care is braking the wheel so help the care rotate
No pull
GT350Brakes.com
Northern California
Tony
GT350 TP
If you have the time I would remove the Caliper and move the pistons in back and forth to see if anything is sticking.
Otherwise it’s possible that while you are trailbraking through the corners that there is some deflection causing the uneven wear.
firestarter2
firestarter2
NYC
RR G350 Track
I will check. I am wondering if the cars stability control is doing it.
Could be a air bubble also I guess but I think that is unlikely.
