P144C Code Help
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
So recently threw this code. Found the problem but i cant find the part. Anyone throw this code yet???
Sent from my SM-N900P using Tapatalk
BGolden
OKC
www.rip tuning.com
2015 EB Mustang & 2015 WRX STI
I have not had that issue. If you need a new one I'd be happy to help you get one. I can quote a price on Monday. I get a good hook up on Ford parts due to a family member.
Boosting Stangs
Rochester Mi.
2015 Ecoboost Premium Competition Orange
I believe that is the EVAP purge valve. It's been a problem with the ecoboost engines since 2009. Random failure causing lean and rich codes. If you disconnect the electrical and the black hose with the zip tie, start engine and place your finger over the inlet where the black hose was. If you feel small amount of suction it means the internal valve isn't closing and it should be closed without electric connection.
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Well Im hoping the Ford house will have one today. I need it for work. Lol.
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Gonna need it today boss. The car is my DD. Lol
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Do you have a part# for this part??
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Sooo i got the new part in. Question is how to i go about taking off the plastic line? I was told heat loosens it up but i tried that and the line just kinda collapsed on itself.
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Tune+
St. Paul, MN
www.facebook.com
Adam
2015 Ecoboost Mustang Automatic
It is fuel, it is because he deleted the check valve and hooked directly to the purge valve. You have to keep the check valve in place and replace the front plastic to the throttle body with rubber hose.
Cut it with a razorblade.
higdominator
Central Oklahoma
2016 GT PPP
I knew he had sucked in something that wasn't supposed to be in there...
Must maintain all check valves, there are like a dozen on this car, lol.
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Replaced and cut properly. I figured i needed that valve
