5.0yote
AKA Bananana & 3.7Cyclone
- Jul 18, 2015
- Mansfield, MA
- Website
- www.youtube.com
- Don
- 2016 Mustang Ecoboost Premium
- Vehicle Showcase
- 1
Just posting this was at the bottom of the article.
Bottom end
High Pressure Die-cast block with ladder-frame strengthening ribs molded around the cylinders and enlarged oil and cooling passages (deck height same as 2L).
9.5:1 CR 87.5mm bore high strength aluminum pistons with fully floating wristpins and steel piston ring carriers. Teflon coated low friction skirts (same bore as 2L but 0.5 lower compression).
94mm 'stroker' crankshaft, Forged 4340 steel (compared to 83mm cast steel on the 2L) lubricated by a chain driven oil pump
Upgraded high volume / high pressure oil pump and pickup.
Die-cast deep sump aluminum oil pan, baffled pickup area to prevent oil slosh, cavitation and starvation during high-G situations.
High volume piston-cooling jets.
Premium multi-layer bearings with low friction coating.
Of course its an older article, and if you continue even to the final pages you will see the prototype heads look to have standard exhaust ports instead of the integrated TS one that we see on the factory part so. IF the internals changed as much as the head, which I am not sure they did that much then who knows, but a "stroker" crankshaft is interesting. So is the forged rods statements. Considering some of the engines that have thrown a rod (albeit wrist pin weakness).
Bottom end
