Opinions on my knock problem
Lgarretto
Oklahoma
Logan
2016 mustang gt pp
Having said that I'll get under there tonight and check again. I can miss things. The smartest idiot is still an idiot
Radar Doc
New Market, Alabama
2020 Ford Mustang GT Premium
I haven't seen your full mod list, but if it's not too much trouble, how about switching back to gasoline and datalog on your stock tune? Wouldn't that possibly steer you in the right direction regarding false knock, clutch problem, etc?
Lgarretto
Oklahoma
Logan
2016 mustang gt pp
Not a bad idea. All I have is an intake and a cat back. I still have cats and stock manifolds. In all honesty I bought the car with both and figured a tune was a cheap 40-50 horse is all. I may go back to stock and log to see if I get knock on the stock tune. Didn't think of that. Thanks
Zrussian13
Phoenix
No. No headers at all. Magnaflow cat back. I've shook it all around and it doesn't seem to hit. The closest thing was the bolt on the shifter strut. Which is still close but there's nothing I can do now. When I bent the trans tunnel out for it my knock went down from 6 to about 4. Then I got a revision with less timing which dropped from the 4 to about 1-2. Tried another degree of retardation for the timing, knock went back up. To about 5 I believe. I'm back to the previous revision now. Logged yesterday with a max of 0 on a 3rd gear redline pull and a max of 2.0 when getting on and off the throttle just spiritedly running through some gears
So you had no knock on the wot but got it on the shifts on your last log?
Lgarretto
Oklahoma
Logan
2016 mustang gt pp
Yes that's correct. While I was driving I kinda kept an eye on the knock on my laptop. I ran 2k to 7500 in 3rd then shifted to 4th and ran to about 6k and didn't get any knock. Then I ran about 3k to 5k or so through 2nd, 3rd, and 4th and got positive 2.0 knock
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I know a guy who on a dyno tried to get his shop mule (mustang) to knock on E85. I think he went to 45 degrees of timing and it still wouldn't knock. Down a ton of HP however.
Lgarretto
Oklahoma
Logan
2016 mustang gt pp
That's what I have heard. And with new plugs and fuel I have verified multiple times I have a hard time believing the knock is real. But I'm not any sort of expert for sure
K4fxd
NKY
Like has been suggested I would try a safe Gas tune and see if it knocks on it.
Lgarretto
Oklahoma
Logan
2016 mustang gt pp
I will do so as soon as I run out my tank
Zrussian13
Phoenix
If it's knocking on the shifts it very well could be drive train related. I was having similar issues on my tt set up and Lund was sure it was false and drive train related. 2 weeks ago I noticed the shift mast weight had fallen off my tranny. I removed the rest of the assembly and put a block off plate in and so far this week no knock. Unfortunately this couldn't be your issue since the weight wasn't added until the 18+
