Oil separators / catch cans
Coyote 16
Perth
Jared
2016 DIB Mustang GT
As a noob knowing I need a catch can for when my stang arrives, can someone point me in the right direction for one that's easy to install and will do the Job. Cheers!
JLT3 very easy to install as it uses the factory hoses and fittings also bottom simply screws off to empty. The hoses have markings on them so you know which way to install. No screws.:)
This is what you need:
JLT Performance Oil Separator 3.0 Black Anodized Passenger Side Kit GT 2011-2017/Boss 302 2012-2013/GT350 2016 from CJ pony parts
jd3v1l
Melbourne
2017 GT PP Auto Shadow Black
JLT3 very easy to install as it uses the factory hoses and fittings also bottom simply screws off to empty no screws.:)
second the JLT3, i got driver and passenger side catch cans. seems a bit silly to only do one side.
noboot
Sydney, Australia
Saf
2017 Grabber Blue Mustang GT
What!!! :lol:
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
If you're not F/I you don't need the driver-side can, run a UPR breather.
phil545
Phil
2016 Mustang GT
Ford Performance is the easiest one to install, can only go on one way :-)
Bolted
Melbourne
Mustang GT Race Red
When I was considering which one to get the three most popular I came across were -
A) Ford Performance- looks OEM, simple install, just plug in hoses. Some people have mentioned that removing can to clean can be PITA.
B) UPR OR JLT can which are both 'plug n play' and sit on hose
C) UPR with remote bracket sits near radiator. This is the one I purchased as I preferred one that was hidden. It takes a little more effort to install.
If you're considering a UPR can I think there is a group buy being organised, so check classified section.
All the cans mentioned do the job, so it just comes down to your personal preference and look you're trying to achieve.
phil545
Phil
2016 Mustang GT
Spot on mate, for the ford performance, i just undo the 4 bolts then use a syringe from the chemist to suck the oil out, makes it real easy!
Streetfighter Mustang
www.streetfighter.net.au
David
2015 GT Mustang
Streetfighter oil seperators are another option.
-Suits 5.0 GT n/a and supercharged
-High quality billet aluminium
-Fit and forget/ no need for constant attention
-Direct fit / no modifications
-100% Australian made
-Available Australia/NZ overnight
$395 for the pair.
[email protected]
08 82999 998
msweet
Sydney
2019 Ruby GT PP 10A w/ Magride, Recaros
I know I've asked before, and you don't sell just the single side, but I think the market would be more open to it. $395 is a lot of money for those that don't want/need a breather on the clean side.
OzS550
Adelaide, Australia
Michael
GT Fastback
I also have Ford Performance, but I haven't attached it to the engine with the bracket. It seems to sit happy in place suspended by the oil lines like other catch cans do.
Then I just unclip the two oil lines and pour out the oil from the lower collection chamber. No mess, no risk of lost bolts.
phil545
Phil
2016 Mustang GT
thanks mate, good tip!
apsilon
Sydney Australia
Grabber Blue manual GT in transit
w0rt3x
Melbourne VIC
MY17 GT Fastback Manual Ruby Red
Back into your manifold :)
David
2015 GT Mustang
Where does the oil go if you don't need to empty it?
The separators act as a return back into the engine when not running.
This lessens oil usage and keeps your manifold clean
noboot
Sydney, Australia
Saf
And you can 100% guarantee no metal shavings or anything but oil goes back into the engine?
