The Chairman
Thanks for the info.As stated above, we have seen 2 instances of FL2062 collapsing in on themselves. One of the collapses happened while the car was on the dyno being tuned. It was a 1000R twin turbo car. The other one was on a 800R twin turbo car that was out in Colorado while the customer was driving it on the street. Luckily both cars had MoTeC ECUs. When oil pressure drops the MoTeC goes in to a fail safe strategy and shuts off the engine. These both occurred around the end of 2020 and start of 2021. Since then we only run the FL2087 filters and have updated our owners manuals stating as such. I would say its not likely to happen in a stock or near stock HP car. This is a picture of the filter out of the 800R from Colorado.
However, not sure I see a link between horsepower and oil pressure. If you are running a stock oil pump at nearly the same RPM, the oil flow would be the same (pressure and volume).
The pix you provided looks like a twisted/crushed install, not collapsed?
