oil dip stick readings
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
anyone else notice that they get 2 different readings on the oil dip stick from one side to the other?
I recently checked and get the lower dot on one side and 1/2 way between lower and upper dot on the other side. I tried it a few times and it was consistent . My Outback is the same and the subi community decided it s the higher side. Thanks.
PS/ yes its level.
Tucker80
Aaron
2022 Mustang CS, 2024 Civic Type R, SV650
It's at an angle. Of course its different on the low side vs. the high side
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
PS/ yes its level.
This is what i did, bulletproof reading... Do an oil change, full 10 quarts.. Then pull stick & see FULL and then try and make a nice metal mark w exacto razor or knife, or sandpaper mark on the stick on both sides where FULL is on it.. anything to get a mark made in metal. After that you will always know its FULL, regardless of fords quacky dipshit dipstick!!! lol
Hope this helps!!
Anthony
Rapid Red
Woodstock GA
Greg
PS/ yes its level.
Ok yes and all cars do that, so here is a question, what difference does this really make?
It is much to do about nothing, would you not say?
So I'll make fun of it........
This is the forum version of a show about nothing. Having equal interest that my pillow 2.0 generates.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Hope this helps!!
Anthony
A carbide scribe would work best.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
My F150 was bad for this, it would read high, I could wipe it off and push it in 180 degrees out and then it read lower. Parked in my perfectly level garage, and having not ran in 2 weeks my Mustang is a little closer, I just read it the same each time and go with it. 10 quarts plus a bottle of Ceratec and then make a note where it reads (it always reads at the top of the hash marks the way I keep the dipstick oriented), mine hasn't dropped hardly at all in 5k miles from there in the 2 changes I have done.
Traffic22
SF Bay Area
Chuck
2018 F-150 Raptor, 2011 Ford CV Lemons Race Car
I’d just be happy if I could get the thing out cleanly around the strut tower brace to get a good reading. Always seems to take 2-3 tires. And no, I’m not physically or mentally challenged. It’s just a really weird angle and always seems to take a couple attempts to get it out without smearing the end of the dipstick…..
…..or perhaps it’s just the dipstick checking the dipstick. 🤷‍♂️
JOKER M1
Somewhere in Indiana
2015 GT Premium (SOLD)
I‘m going with the “or perhaps” statement
JOKER M1
If I check mine after it sat for a couple days I can get a pretty clean read on both sides but it also depends on how (direction) the dipstick is inserted 🤷🏻‍♂️
Traffic22
SF Bay Area
Chuck
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
You gotta grip and twist your stick just right to get it out. I have the tower brace too, and what I found that works for me is to pull it out and towards the front of the car. Once the stick is almost out, then you slow your tug to avoid touching the inside of the hole and messing up your reading.
RagmopInKona
CEO
2020 Mustang HHP
Or just tweak the dipstick tube so it clears .
cerbomark
cerbomark
TN
OOO, I can answer that one. It makes No difference, I m just curious.
3pdl
us
'19 mustang gt pp1, '82 f150
best thread ever.
