TheNameAndy
I'm trying to stay close to what the manual recommends but at the same time I also want to best for my car. If there are better synthetic oils out there, I would prefer to use that..So the motorcraft full synthetic will be just fine?After all the research I've done on motor oil, I've come to the conclusion that, unless you are subjecting your engine to an unusual amount of stress, such as a lot of track time and WOT, or you have a heavily modified engine, then any major brand of synthetic 5w30 that meets Ford's WSS-M2C946-A spec is fine. I know that there are conventional and synthetic blends that meet that same spec, but full synthetics resist heat better, and just make more sense for turbos.
Yes, there are exceptions; Rotella T6, being one. T6 is a diesel oil, and so doesn't meet the Ford spec because, for one thing, WSS-M2C946 stipulates a 5w30 oil, but it has been used successfully by many knowledgeable people for many years in turbocharged engines.
I am starting with 5w30 synthetic, and will be getting UOA's every oil change to make sure the oil is still good at the end of it's use. If I find that the oil is not keeping up, I may very well go to something like T6.
BTW, I don't track my car, but I do like to drive enthusiastically, and I will be doing simple bolt-on mods; tune, CAI, exhaust, etc.
