Offset help suggestions
Lowkeyslow
California
David
2019 Mustang GT
So I already got wheels comin in the mail. They’re 20x10 +38 front and 20x11 +22 rear. I’m worried that the rear might be way too wide and will poke out. Does anyone run this? Is there a way I’m able to fix the rear setup by adding camber? What are your guys’ suggestions
NightmareMoon
2016 Mustang GT PP w/ Voodoo
The rears will poke for sure, close to 3-4cm of poke is likely.
It would take extreme camber to tuck those rears in, which would reduce your rear grip. If you do add camber, keep it at or under 2 degrees.
best to return the wheels tho, they don’t fit.
m3incorp
Georgia/Colorado
James
I'm surprised the vendor you bought them from, didn't try to talk you out of that offset.
ugstang17
unknown
none
tons of 411 on proper offset sizing for 05 top present wheel sizing. +22 will stick out like Joe Dirt. You are off by +23mm on a 10.5" width wheel on the rear and even more on the 11 inch you wish to use. Look at sizing on wheels offered on TEAMBEEFCAKERACING website.
LxMike
tenn
2017 Mustang Gt.
Get a wheel with right offset for rears.
