sox3
- Jun 2, 2019
- Newark, Delaware
- George
- 2019 GT 350 Performance Blue
Corsa X here as well.
Again, having spent a while looking into it and listening, there was simply no reason to spend double the money on a Corsa X than a Lethal Performance X. Same types of stainless steel, same diameter. I guess people just really want that name.
I just put the lethal x-pipe on mine this weekend. Good quality (Made by Stainless Works), easy install, and sounds great.Again, having spent a while looking into it and listening, there was simply no reason to spend double the money on a Corsa X than a Lethal Performance X. Same types of stainless steel, same diameter. I guess people just really want that name.
Yep, had it done in under an hour, and haven't regretted it since. It hasn't been a year yet, but its getting closer.I just put the lethal x-pipe on mine this weekend. Good quality (Made by Stainless Works), easy install, and sounds great.
You had it done in under an hour, or you did it in under an hour?Yep, had it done in under an hour, and haven't regretted it since. It hasn't been a year yet, but its getting closer.
I did mine in right at an hour, including jacking the car up, and taking it off the jack stands.You had it done in under an hour, or you did it in under an hour?
Where you at North of Houston? I'm in Spring. I have my Lethal Performance X pipe in my trunk and went to 3 places this past weekend and had zero luck finding anyone to install it. The one place that would do it wanted $350. I can pay you in beer if you'd help me out.I did mine in right at an hour, including jacking the car up, and taking it off the jack stands.
I am up in the Tomball area. Busy for the next couple of weekends though. If you don't mind a bit of a drive, hit up Bryan Luna at Ace's Performance Exhaust in Pasadena. He'll knock it out quick for you for under a hundred.Where you at North of Houston? I'm in Spring. I have my Lethal Performance X pipe in my trunk and went to 3 places this past weekend and had zero luck finding anyone to install it. The one place that would do it wanted $350. I can pay you in beer if you'd help me out.
Thanks for the recommendation, i'll hit him up. I work downtown so won't be that bad.I am up in the Tomball area. Busy for the next couple of weekends though. If you don't mind a bit of a drive, hit up Bryan Luna at Ace's Performance Exhaust in Pasadena. He'll knock it out quick for you for under a hundred.
I set mine up to bolt the oem back in. Turned out helpful when I sold the car.Just placed an order for the LTH X-Pipe. Really liked that it matched up at 2.75" with the R. Now debating whether to pull out the saw and do the install myself or pay a shop to do it (rather not be on my back hacking away under the car). Also thinking of having the original piece modified to allow it to bolt back up with the second set of clamps as an option for quick changes (if ever needed). Anyone ever try something like that?
