Noise after Intercooler install
MattSin97
California
Matthew
2018 Mustang Ecoboost Premium
Hey everyone, just got a CVF Street intercooler installed the other day. I took it to a shop that specializes in Mustangs, so I thought everything would be good to go. However, I noticed that there is a sound that wasn't there before, it sounds kind of like more air sucking in when boost hits. I'm not sure if this is a boost leak, or if it has something to do with the active grill shutters being removed. Has anyone dealt with this before? Should I be concerned?
FreePenguin
Ohio
Donald
17 mustang
if you have boost leak you’ll have less psi boosting.
Shutters won’t change any sucking noise.
Either you got a new intake or filter
or, charge pipe is leaking at one of connections.
That’s my guess.
93coupe/stroked
Deep in Louisiana
Michael
2020 ecoboost base auto metalic
When I swapped my stock intercooler with a Mishimoto intercooler, I left the grill shutters in. In my state it hardly ever get below freezing! As for the sound your hearing could be a leak from a loose clamp, did you notice if your down on boost numbers?
MattSin97
MattSin97
California
Matthew
I will take a drive around and see how the boost numbers are looking
MattSin97
MattSin97
California
Matthew
It gets up to 19-20 PSI still. I notice the sounds occurs while accelerating up until around 3000 RPM.
FreePenguin
Ohio
Donald
17 mustang
Do you hear it while driving or only in boost? Like, cruising? 0 boost, hearing sucking.
sucking is either intake, or charge pipe loose. No other way around it.
wish I could help. Does it stay at 20? Feel like it’s struggling to maintain? Longer than usual to get there
MattSin97
MattSin97
California
Matthew
It makes the sound right before boost then it sounds like it sucks in and closes around 10 PSI. I just came up the mountain and it feels the same. I haven't really pushed it hard where it stays at 20 PSI though.
MattSin97
MattSin97
California
Matthew
I just want to make sure nothing is going to be damage since I won't be able to make it to my shop for a few days.
whatdoyoufeedit?
Fayetteville, NC
2019 Race Red EB A10 (Formerly 2016 3X Yellow V6 M6), 1996 Mercury Cougar XR7 4.6L A4 (Future Coyote swap candidate)
MattSin97
MattSin97
California
Matthew
