EFI
- May 19, 2015
- Masshole central
- 5.Br0
I've seen several cold air intakes that offer both a tune required and no tune required versions of seemingly the same product. One particular I forget what it's called has an insert in the intake tube that makes the area around the MAF the same diameter as stock, while the rest of the tube is the same size (and I assume bigger than stock).
So what makes that particular setup not need a tune? Does a certain area around the MAF itself have to be the same diameter as stock and thus the OEM tune is fine? What about the rest of the intake tube diameter?
