Nitrous plus E85 question.
Zinc03svt
usa
stang
Anybody running the E plus nitrous? I would more seriously look at this option if I could stay on the E with the nitrous tuning. 100-150 shot wet.
Driving around in sackless pump/spray tune (normal driving) does not appeal to me.
Thanks
Rjames18
Houston
RJ
2018 Mustang GT A10 Orange Fury
On my 3.7 mustang I was on a E85 tune and sprayed a 150 shot. seemed to work just fine.
Kona 18
2018 Mustang
Zero issues running e85 on nitrous, the only thing about running it on a 2018 is you need to make sure you use the correct fuel pill if you plan to tap into the stock fuel system. The Coyote runs about 72-73psi at WOT, so you can't use a 40 or 55psi pill, you'll need to play with the pull sizes until you find the correct fuel pill to use
Notagain
United States
yellow 2016 5.0 totaled white 2018 A10 now
I want to do a 10 sec NA/spray setup on my 2018 10R80. I just want a simple 10 sec car that doesnt cost 5 figures in parts!!
Wheels tires suspension converter and e85 will be 1st tho.
Sub'd for results Id love to see how it turns out!!
