NGauge as gauge
El_tucanaso
California
Jose
2020 mustang gt; 1965 mustang fastback
I just slapped on a Vortech to my ‘20 GT and I like the look of the NGauge as a gauge (in the ac vent) to get readings. Now, my question is: since I am not going to use it for tuning purposes, do I still need an unmarried NGauge if I am only going to be using it as a gauge to read things knock, lambda, etc.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I had a Ngauge on my S197. I tuned with it and left it connected for the gauges all the time, I don't see an issue.
The Demon
Brett
2022 Mach 1 N5809
I believe it does have to be unmarried. If I’m not mistaken you get three unlocks for an Ngauge if you could find one used. I know that’s what Lund does but I’m not sure about others.
El_tucanaso
El_tucanaso
California
Jose
I just wanna be 100% sure, seeing as a married one can be found cheaper and I only want it for readings.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I guess I misunderstood your question. I think it still works but I am sure someone here can give you that answer.
I was looking for similar gauges and found this below, kind of interesting.
https://www.aliexpress.us/item/3256...47098d&afSmartRedirect=y&gatewayAdapt=glo2usa
I don't know anything about that site ^ . LCD gauge like that would be pretty cool. If anyone has any info on this one or others like it.
m3incorp
Georgia/Colorado
James
I have an nguage that I bought off here. It was married to another vehicle but works fine for normal guage/monitoring. You just can't tune with it.
El_tucanaso
El_tucanaso
California
Jose
Thanks this is what I needed to know!
rolfe.oliver
St. Louis, MO
Oliver
1967 Mustang GT350 Tribute, 1971 Mustang Mach 1
To double down, a married nGauge is okay for logging, using it for gauges, crank relearns, KAM resets, and code reading/clearning. ONLY for flashing does it need to be married.
El_tucanaso
El_tucanaso
California
Jose
Appreciate the info.👍🏻
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
What are people usually displaying with these? I usually have knockr, cat temp and lambda on the screen. Is there anything else I should monitor?
