Ngague datalog file are not saved
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
I follow the directions on dataloggin with my Ngague and tap the screen, says recording, shows a file with a log name on the screen but when removing the sd card the log is nowhere to be found, but If I log only one parameter directly at the gagues screen the log file is saved
Could somebody help me out on this one?
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
What log name is it giving?
16s550
Bay area
2016 GT M6 performance pack, whipple charged
Are you tapping the screen and the yellow light starts flashing?
beefcake
Bethel
2018 Ford Mustang
Yep light should be flashing
v8ter
v8ter
Typing...
EL PASO , TX
Im gona do it again this eve after work,the light was flashing and the name said something which Im gona confirm but I think it showed log042
v8ter
v8ter
Typing...
EL PASO , TX
Yes, I go into diagnostics- datalogging - select a config file that lethal performance sent me (2011+ Pids) select it, and tap the screen and the yellow light starts flashing and the name of the log shows on the top of the screen, so I press the x on top right , removed the sd card when the ngauge was off, and no file is saved on the sd card
yellowstangatl
Minnesota
2024 Dark Horse Premium
What folder are you looking in for the the logs?
v8ter
v8ter
Typing...
EL PASO , TX
looked into every folder and no logs are there, Im gona redo it and see if I can find any difference
v8ter
v8ter
Typing...
EL PASO , TX
So on the gauges screen, when I tap lets say spark it shows to log it, and a file is created then, so I deleted every file in the logs folder and retried and now the files are saved when doing the datalogs, so can someone help me out what I should look at for when I go to the track?
I cant find spark on the pids, and would like to know if Im running on good timing or not
A file was sent to me from lethal performance, it says 2011+PIDs_GENERIC_R6.dle
Jay-rod427
Kansas
2016 GT C/S
You at missing the datalog config file. See your other post for the files needed. Also the spark is labeled saftot or something like that on the logs spreadsheet.
v8ter
v8ter
Typing...
EL PASO , TX
How did you know this? Saftdot sure looks alot like timing, its around 21 so that should be it, I appreciate your help man!!!!
