Lund Nguage Datalog config file?
GDP
2016 GT Base Deep Impact
Anyone have this file or can copy it from their device?
Should be called 2011+PIDS-LED-AFR-NA.dle under the config folder of the device.
beefcake
Bethel
2018 Ford Mustang
GDP
if you flash the most updated software, the config file will be in there
https://support.lundracing.com/hc/en-us/article_attachments/207145448/FIRMWARE-195.ng
I actually did that, there is a file but its called 2011+PIDs_GENERIC_R5.dle is that the right one? From what ive been able to google the file name is/was 2011+PIDS-LED-AFR-NA.dle
did it just change is all? Just wanting to make sure before I datalog. I have a ticket in with lund and asked this question but figured if I can get a quicker answer from the community it will take the workload off them.
Also any idea if its normal to see around 5 degree timing pulled at WOT with the nguage under KNOCKR? I figure it might need a little fine tuning.
beefcake
Bethel
2018 Ford Mustang
the file in there will be fine
