jefffrot
- Sep 2, 2015
- Wentzville, MO
- Jeff
- 2016 Mustang GT CS
MikeI was updating from 18025 to 18093 and continued to get the same error message regardless of what I tried (disconnect battery cable to dump anything resident in memory, turning off blutooth etc). I read on other Ford sites and the problem has to do with the limited memory available in the non-nav apim. (As is often stated - it has nothing to do with your flash drive). Some had success rearranging the order of the file installations but I found that their order solution was the same order as the present download for the Mustang. It didn't work for me. Some did re-installs back to earlier versions (your 2.2 for example) but you are there and it isn't working for you. It's been determined that the install gets hung up on the 451.3MB and/or 772.1MB files; there isn't enough memory to unpack them both. Their workaround was to delete some of the files, do the install, then delete the other files, while restoring the first deleted files, and do the install again. None of the directions I found were done on 18093, this most recent one, and there are a different number of files with different names across the models, so really nothing to go by.
SO.... Fools rush in where angels fear to tread.
Here's what I did, I started with removing only one file at a time and it seems to have worked flawlessly.
1. Unpack the JR3T-14G381-AM.zip to your desktop and copy the contents of the JR3T-14G381-AM folder to your flash drive. Work only from your flash drive from this point on.
2. Delete the JR3T-14G423-BA.tar.gz file (772.1mb) from the SyncMyRide folder on your flash drive.
3. Open the autoinstall.lst with a text editor (TextEdit on a Mac or Notepad in Windows) on your flash and delete lines - Item3 and Open3.
4. Remove the spaces where Item3 andOpen3 resided and rename Item4 and Open4 to Item3 andOpen3. EVERYTHING ELSE SHOULD STAY AS IT IS.
5. Save the file with the same name - autoinstall.lst.
6. Take the flash to your car and do the install. It should update successfully and basically tell you that you are finished. But you are not. (I checked the Sync screen and it still showed 18025).
7. Take your flash back to your computer and do the same thing except you will copy the "BA" file from the SyncMyRide folder on your desktop to the same folder on the flash drive.
8. Now, delete the "AM" file - JR3T-14G381-AM.tar.gz (451.3mb) on your flash drive.
9. For simplicity sake, I copied the original autoinstall.lst from the desktop and overwrote the modified one on the flash drive and did steps 3,4, and 5 again, this time deleting Item2 and Open2 lines, removing spaces, and renaming Item3 and Open3 to 2, and Item/Open 4 to 3
10. Repeat step 6 and it SHOULD work for you (caveat emptor). I checked the Sync screen and it shows version 18093. I tested all the functions and everything seems to work fine. It even seems to be quicker - but that could be me wanting it to be so!
Godspeed!
Thanks for the very detailed instructions. Just so I got this straight, the first time you got rid of item 3 in autoinstall.lst file, renumbered the file then got rid and the associated tar.gz file. Everything else was left the same. After installing step #1, you started step #2. At that point, you started back with the original file that was downloaded from Ford. This time, you got rid of item #2, in the autoinstall.lst file, renumbered the file and then got rid of the associated tar.gz file. Everything else is left the same? At that point, I’m ready to install step #2. Did I miss anything?
Thanks,
