Semp1
Needed to show how great these look in gloss black. Staggered 275/305 NT05’s with a modest drop by the ford performance lowering springs for magneride.
It isn’t so much the diameter of the wheel as it is the size of the barrel of the wheelloving those Rims... but why do they not fit 350 brakes? GT350 arent supposed to have 19 inch rims too?
so... if I install GT350 brakes on my car Im ok to go?It isn’t so much the diameter of the wheel as it is the size of the barrel of the wheel
If they say those wheels don’t fit over gt350 brakes, then they probably won’t fit. You can have two wheels that are the same diameter and width but one wheel fits over gt350 brakes and the other doesn’t. A good example would be Apex wheels. Their 18” ec-7 (for mustangs) wheel was designed to fit over performance pack brakes. Off the top of my head, I don’t know of another 18” wheel that will fit over pp brakes. Their 18” wheel has an 18” diameter just like the rest of the 18” wheels, but they designed the barrel of the wheel to be larger so that the calipers won’t come into contact with the wheel. It all comes down to the size of the barrel of the wheel. And the spoke design but that’s another issue for another threadso... if I install GT350 brakes on my car Im ok to go?
haaa ok now I understood what you mean with barrel of the wheel "english is not my main lenguage" thanks for the heads up. I´ll search for this if not, I think I will go with the 20 inch Shelby GT that looks like those but larger , sad part is... they are almost 400+ usd per rimIf they say those wheels don’t fit over gt350 brakes, then they probably won’t fit. You can have two wheels that are the same diameter and width but one wheel fits over gt350 brakes and the other doesn’t. A good example would be Apex wheels. Their 18” ec-7 (for mustangs) wheel was designed to fit over performance pack brakes. Off the top of my head, I don’t know of another 18” wheel that will fit over pp brakes. Their 18” wheel has an 18” diameter just like the rest of the 18” wheels, but they designed the barrel of the wheel to be larger so that the calipers won’t come into contact with the wheel. It all comes down to the size of the barrel of the wheel. And the spoke design but that’s another issue for another thread
Edit; that’s typically why you see 15+ gt/v6/eco spec wheels, and then gt350 and gt350r spec wheels. That and the widths and offsets
I have this setup. You're gonna like it!I ordered the package after days of debate with myself. I went with the NT05 like I said said in the above post. Black wheel package. And added the gt350 center caps. For no other reason than the Shelby caps just look “cleaner” than the SVE ones. looking forward to it.
I love them. Need to be cleaned a little more often due to brake dust but whatever.I have this setup. You're gonna like it!
Rob
What size wheels and tires? What brand tires?A forum member asked for a pic in daylight of Graphite SP2 on Ingot Silver. Thought I’d share here. In most light conditions, they look like a lighter shade of black - and I’m good with that. No regrets.
I got the 19x10/11 combo. Nitto Invo 325/30 rear and 285/35 front.What size wheels and tires? What brand tires?
Every wheel in this post is 19in by either 10 or 11.What size wheels and tires? What brand tires?
Have any rear end shots?I got the 19x10/11 combo. Nitto Invo 325/30 rear and 285/35 front.
Eibach Pro Kit and zero rubbing.
