- Dec 8, 2014
- San Luis Obispo, CA
- 2002, 2006, 2015 Mustangs
If you are using a stock shock or a stock OE dimension replacement you won't use any of the supplied spacers or reducers. If you are using an aftermarket shock that uses a 12mm shaft you will use the smaller ID reducer. The larger ID reducer is for the MangeRide shocks and the 12mm washer is for shocks such as Koni that has a longer threaded portion on the top of the shock.
