Need advice on new wheels and tires
2016 GT/CS Laila
Oklahoma
Dennis
2020 Mustang GT, 2021 F150 Lariat 4x4, 2018 Taurus
I plan on purchasing a set of Ford Performance PP2 style wheels 19x9.5 front and 19x10 rear. I am trying not to adjust the stock tire diameter too much and have decided on 265/40R19 front and 295/35R19 for the rear. Anyone see a problem with this, my current set up is 19x8.5 with 255/40R19.
Grintch
Hunstville
2015 GT PP
Going from 255 square to 265/295 will cause a significant increase in understeer. 295/35R19 has little tire selection. 295 is wide for a 10" wheel.
Just go 275 or 285 square on 10" wheels. It will handle better, and have better tire life being able to rotate the front and rear tires.
A little change in diameter is not a big deal. Many people obsess far too much over it. But 275/40R19 should minimize it, and still have pretty good tire selection (but not as good as /35).
Labradog
Santa Barbara, CA
Jeff
2016 Mustang GT Guard Metallic
I'd second the recommendation for a different (ideally lighter) set of 19x10 square wheels with 275 or 285 tires, but if you are dead set on those I'd go 265/40 front 275/40 rear.
2016 GT/CS Laila
2016 GT/CS Laila
Oklahoma
Dennis
2016 GT/CS Laila
2016 GT/CS Laila
Oklahoma
Dennis
I’m not dead set on that set up, my other option is to source out 4 9.5x19 wheels. My current wheels have a 42.5 offset and the FP wheels have a 40 which is pretty much a wash leaving a width increase of an inch, just under a half inch on the inside and just over on the outside. At that point I would probably go for a 275/35R19 squared.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
I suppose another option for those FP wheels would be 275/35 front and 285/35 rear. But I agree with the other posts about better options. The widths of those wheels (9.5 front and 10 rear) make it more of a challenge to choose tires with appropriate diameters and that consider the selection/availability of certain tire sizes.
shogun32
Northern VA
Ford wheels are stupid heavy.
19x9.5 et30-40 or 19x10 et30-37 come in zillions of options and prices. 9.5 rims can happily support 255-275/40, 275-285 for the 10s.
Since you don't appear to have Brembo 6-pots, you might also try the 18x9.5 or 18x10 fitments.
Code:
Limits (in)    outer    inner
  S550 F    3.7    6.6    70.5
  S550 R    3.5    7.5
19x9.5 ET22 c    3.9    5.6    ESR RF02, VMR v710/705
19x9.5 ET30    3.6    5.9    Forgestar F14
19x9.5 ET33 c    3.45    6.0    Centerline 670GM, VMR V705
19x9.5 ET35    3.4    6.13    Konig CG9N514357, Enkei TFR copper, tire barely inside rear fender - looks poke
19x9.5 ET40    3.2    6.3    Drag DR48
19x9.5 ET45    3.0    6.5
19x9.5 ET53    2.66    6.8    PP1
19x10 ET20 c    4.2    5.8    SS1LE (sticks out 5mm w/o camber, about 10mm to strut), VMR V703
19x10 ET25 c    4.0    6.0    VMR V703/801/810, XO Moscow
19x10 ET30    3.8    6.2    Curva C300
19x10 ET35    3.6    6.4    MRR M600, 3-5mm spacer (front)
19x10 ET40    3.4    6.6    RTX GT350R
19x10 ET42    3.5    6.65    Forgestar F14
19x10 ET45    3.2    6.8    will NOT clear
DonnieO
Donnie
2017 mustang gt cs
19x10 square 275/40/19
