Need a quick favor
UnhandledException
States
2017 GT350
I am trying to adjust the muffler tips of the FP/Borla exhaust and need someone to measurs how far in the stock tips sits. The easiest way to do this would be to measure the distance between the precut holes (the second one that is closer to the front of the car) and the tip of the exhaust. I would really appreciate this!
S550VIN54
Raleigh NC
Stephen
2021 FJG Mach 1 HP
Not sure how accurate this needs to be but I measured roughly 2"3/4-2"7/8 from the center of the hole closest to the front of car to the end of the exhaust tip on mine.
If I measure from the front of the 2nd hole meaning I am resting the end of the tape rule from the top of the circle back to the tip I am seeing about 3". Hope this helps!
For the record, there are 3 holes one very small one closest to the tips and 2 larger holes...I used the 2nd larger hole.
UnhandledException
States
2017 GT350
Oh wow, so almost 3 inches of space there? Thats a lot. The exhaust I have is basically the tip literally rests on top of the second big hole.
Thanks so much for helping out though.
Offboost
Sin City
2018 JR101 Kona Blue R Sold 1/21/19 New 2019;Ruby Red Raptor
If you measured while hot the exhaust will be expanded. I just checked mine and the outer tip ends are even with the middle of the second hole most forward with exhaust fully cold. Exhaust has never been removed or cut.
