Hi Nick,Like FLStang suggested, make sure they are installed correctly in the socket. If you are still having issues, please give us a call: (314) 205-3033
Our customer service team will make sure you are taken care of
Thanks,
Nick C.
Please take pics of what you end up doing to the pins. I was asked to do the same first and I looked into every pin in detail. I even switched the left bulb to the right side and vice versa, but the lights still flicker after a few minutes. :(Mine are doing the same thing. I called them Thursday to see what I should do about it and he instructed me to take them out and make sure they are installed properly, and make sure the two prongs are bent out enough to make good contact. I will give this a try and will post the outcome. I would imagine that after spending $80.00 on bulbs that DD would be happy to replace them if I continue to have the issue.
We just have to make sure it's not a pin-alignment issue with the bulb in the actual socket. If you've checked that and the issue persists, we will issue warranty replacements.Mine are doing the same thing. I called them Thursday to see what I should do about it and he instructed me to take them out and make sure they are installed properly, and make sure the two prongs are bent out enough to make good contact. I will give this a try and will post the outcome. I would imagine that after spending $80.00 on bulbs that DD would be happy to replace them if I continue to have the issue.
I have just been communicated by Nick from Diode dynamics, and they have shipped me another replacement of light bulbs plus resistors. Hope the replacements work. Will keep you guys updated.just installed my switchbacks.
the switchbacks keep flickering. what seems to be the issue?
check the video
The tail light issue is a TSB issued by Ford.I'm having a similar issue; my lights are flickering between white and orange, for one bulb, and the other completely knocked out my tail light and doesn't work. I pulled them out and put the stock ones back in, I couldn't believe for the money spent I would have something like this happen.
That being said, Nick I've sent you a PM with regards to this
