My Ingot Silver V8
Maoilearca
Hampshire UK
Mustang 2016 GT Auto Coupe (Guard). FP PP2
The noise wouldn't sound like this resonator rattle in the video?
Hopefully not - because if this is common enough issue (normally fixed under warranty) I wonder what Ford would say if it happens AFTER an exhaust upgrade (their policy towards any problems after an exhaust modification being 'it will not invalidate the warranty as long as the issue does not stem from the exhaust' - and who will be the judge of that?)
Eclipsar
UK
NFG Mustang GT
Congrats mate hope you enjoyed the day, fingers crossed the rattle is nothing major
By the way did this actually happen as I don't see any photos :lol:
zero7
Warwks
V8 GT
Cograts, take it easy whilst the roads are still cold...
SSC
Lhanbryde, Scotland
I guess these sticky pads you stick them on with won't damage the paint when I pull it off?
Use fishing line or dental floss between the plate and the bumper, try a sawing motion and it will cut through the pads. You will need new pads and have to remove the remaining pads bits but won't damage the paint.
[ame]
jord79
West Yorkshire
Tip on removing numberplate stuck with sticky pads:
Use dental floss between the plate and number to 'saw' through the sticky pad. It takes a bit of perseverance. You'll be left with half the sticky pad on the car, but you can then soak it off and polish the residue away before reapplying.
Lazyitis
Gloucester, UK
Paul
GT
Congrats Twiggy. I think mine may be doing something similar. At first I thought it was the climate control - that kind of gasping noise when the system kicks in which I guess could be likened to your rice description. But I now know that it's coming up through the the shifter boot and there is more high frequency vibration in the lever than I remember from the demo. The noise reduces a lot if I grasp my, ahem, knob :) tightly, so it's either resonance....or our gearboxes are buggered. Question for me is do I start the inevitable cycle of half dozen failed dealer investigations or do I crack on installing the Barton as planned and hope I find and sort the source of the problem? Will decide after another drive today.
Centurion07
Hampshire, UK
2015 GT
I'd be taking that^ to the dealer first.
If, as you say, it's related to the gearbox/stick somehow I can't see Ford taking too kindly to you having fitted a non-oe shifter.
Must get round to fitting mine too! ;)
SteveS
...Bon Scott Land...
Bon Scott Land
Mustang GT Magnetic
Most aftermarket exhausts that are being fitted don't have resonator boxes.
Definitely what he says! :)
Kristian87
Super Moderator
Moderator
Newbury, UK
Mustang GT
Congrats Twiggy...no idea on the noise I'm afraid.
Where abouts in Berkshire are you? Will look out for you :)
Col3371
Oxford, UK
Colin
5.0 Ruby Red GT
All over Berks now he has his car :lol:
twiggy
Berkshire
Mustang GT
That's a great idea!!! Cheers matey!!!
twiggy
Berkshire
Mustang GT
Yes it's a right pain as I didn't want to drive the car much until I got the underseal done, and the only way to sort the sound out is to drive it but until it's done i'm reluctant, one thing I noticed is I found going into 5th gear a struggle and I was have to push hard to get the gear stick into 5th.
I recall someone else on here who's car arrived around the same time as mine was just about to collect it and the dealer called to say they'll have to wait as they found a problem with the gear box.
twiggy
Berkshire
Mustang GT
Well I took her out again today, it did it a few times, It seems to happen when I'm driving very slow and maybe it's in to higher a gear when I increase the speed, i'd almost say it was a vibration type of sound so i'm sure now it's gear box or drive shaft related.
