My build
ldp82
MA
GT350, Genesis 5.0 & 996 cab
First off, build is probably the wrong word. I would call this more my eclectic assortment of subtle tweaks. Build does roll off the tongue a little better. My car is at the shop now getting most of the stuff done.
This is to be a streetcar at this point, so NVH has to be kept at a reasonable level. Reduce some of the “floatyness” of the car and sharpen the steering some. The car drives big, I would like it to feel a little more nimble and communicate a little better.
I thought the first place to find improvement would be a reduction in unsprung rotating mass so wheels were ordered
Signature SV501 wheels 19x11 et 50 in gunmetal these with studs and spacers are rotatable
from Steeda I bought:
Cradle alignment
Jacking rails
Front brace
Vertical links (poly)
Clutch spring
Rear lower control arm bearing
From others
OP mustang front lower control arm with brake deflector and bearings
MGW short shift kit
BMR cradle lock out
Ford racing toe knuckle bearing
Ford racing catch cans
Caliperfexion brake studs
APR studs front and rear with open lug nuts
25mm front spacers
no drill front plat
JLT rock blockers
Airaid filter
FTBR front endlinks
Zl1 add on splitter guards
Ti shims
Spare tire
DSC controller (on its way)
I am looking to add camber plates, x-pipe and carbon drive shaft later this year or next.
Please let me know what your thoughts are on these mods
Deca
NY
17 GT350
impressive! what spare tire solution did you go with?
H6G
IN OMNIA PARATVS
Far from home.....
'17 GT350
Cradle alignment
Jacking rails
Front brace
Clutch spring
From others
MGW short shift kit
BMR cradle lock out
25mm front spacers
no drill front plat
JLT rock blockers
Airaid filter
FTBR front endlinks
Ti shims
Spare tire
A very impressive list of mods.... Just out of curiosity, which shop in MA did you choose to have these mods installed?
ldp82
MA
H6G
IN OMNIA PARATVS
Far from home.....
'17 GT350
Demonic
Boston
GT350R
PAWOLF
QUEENS, NY
17' GT350
Cradle alignment
Jacking rails
Front brace
Clutch spring
From others
MGW short shift kit
BMR cradle lock out
25mm front spacers
no drill front plat
JLT rock blockers
Airaid filter
FTBR front endlinks
Ti shims
Spare tire
Nice list !! I'm actually trying to get the spare tire for a piece of mind sometime next month as well. As far as the ZL1 add on splitter guards goes, let me know how you like them. I've seen mixed reviews that they don't really do their job that well and some love it. It's a cheap mod to protect the splitter guards but I wouldn't want to put it on if it doesn't do anything.. :headbonk:
ldp82
MA
They look easy to install and are cheap. With minimum scraping I am seeing more wear then I would like on the splitter fasteners. If they protect the hardware they are worth it to me. I hope to get them on one of these weekends.
ldp82
MA
I had to go to the dealer for a warranty issue. Drivers outer CV boot failed. Common issue unfortunately. While I was there I also ordered GT350R springs and GT350R rear sway (the front bars are the same) I did this as I wanted the car to react a little quicker with out a big drop in ride height.
I am giving this a shot as the wheels and spherical bearings have really improved the ride. Yes the bearings let in a little more road noise but the car feels like it rides softer.
If anyone cares to know here are the part numbers: (the first 2 are the rear as they are handed)
FR3Z*5560*W
FR3Z*5560*X
FR3Z*5310*M (front springs, you will need 2)
REAR SWAY BAR
FR3Z*5A772*E
REAR SWAY BUSHING
F2GZ*5493*C (you will need 2)
these are the latest revision part numbers (as of today!)
tdzee
Atlanta Motorsports Park
Tom
85 Corvette, 04 Corvette Z16, 08 350Z NISMO, 15 CTS-V Coupe, 17 GT350R
Whose Ti brake shims did you go with?
Thx :ford:
ldp82
MA
As I can not leave well enough alone. I ordered FTBR upper camber arms, cortex rear endlinks, Steeda Rear Camber Adjustment Kit & QA1 carbon drive shaft. Hope to have these in soon.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
Just for thinking ahead's sake, if you're doing just a street car, DO NOT let anyone convince you that you need to upgrade your sway bars. You'll get zero benefit until you hit track or autocross and depending on your skill level, you may never feel a difference.
ldp82
MA
Thanks for the heads up. In the miata community we called (over sized) sway bars live axle conversion kits. I do not want to add too much roll stiffness at this point! The reason for doing the rear bar (to factory GT350R bar)was for the change in spring rate going from regular to R springs. I am hoping Ford did good job of selecting sway bars for the spring rates they picked.
