Mustang Experts please help identify this plug!
tuffycycle
2016 Mustang GT
Had to take apart the door card on my 2016 S550 GT because I heard a rattling sound.
Found this wire unplugged on the driver's side door and can't find the male end. It is on the opposite side of the window(side of outside door panel) so I know that it does not go to door card/speaker etc. as the window would block it when down
Thanks!
Roger Blose
Fairfield, CT
Roger
2018 Mustang GT, 1988 Mustang GT, 2009 Lincoln MKZ
Perhaps a plug for the optional memory power seat?
Skye
≈39N
"Skye" Mach1 N2144
Owned the car since new? Used?
As noted earlier, it could simply be a plug for which there was never an end. Over time, whatever was keeping it in-place worked loose.
Everything still working, yes? No alarms or lights?
Bikeman315
Myrtle Beach, SC
Ira
The only items that uses power on the skin side of the door would be the sideview mirror and/or the door handle. If those are both connected I'd check with a dealer to see what it is.
Replicator
Indiana
Rob
2019 Mustang GT (RS3 Clone)
Possibly for the optional heated mirrors and/or blind spot awareness system?
Replicator
Indiana
Rob
Did I just not mention the sideview mirror? :facepalm: Kidding!:cwl::crackup::like:
You did. I was running with the assumptions you had only power mirrors and there was a separate connector built in for the options. Not much else that can be in the door and I'd assume Ford would use a one size fits all harness.
So you have the my color ambient lighting in the door pulls? If not, it may be the harness to the ambient LED that is attached to the door pull.
