MT82 + RXT Poll
How Long Has Your MT82 + RXT Lasted?
  • Total voters
cdmustang2016
I want to see how long your MT82 + RXT combos have been living.
I am starting to sense a band wagon theory on the RXT clutch breaking the MT82. I am only aware of one professional source (Ben Calimer) who has openly confirmed the RXT to be a route cause of a lot of MT82 failures. I want to see what people are really seeing.
Just crossed 3k on RXT w MT82 and BOOM, 4th gear gone. Boosted car, not tracked. Barely even driven.
Know another person same set up as me, 2k on RXT w MT82 and also 4th gear gone about a weeks ago.
WTF!
whatsup62
Jupiter
WTF!
Welcome to the club!
Learn from my mistake and dont do the same thing twice.
Ditch the RXT or the MT82...I chose the MT82.
cdmustang2016
For Anyone that stayed with MT82 after failure, what clutch did you go with instead of RXT?
Saywhen
Crandall GA
Harley
2017 gt350,2015 f350 lariat,05 Acura rsx,19 gt 10r80 on order
347CobraII
iowa
2015 GT
I'm I seeing this right RXT clutch has no damper springs in clutch discs. If that's true I can see why it's hard on transmission
whatsup62
Jupiter
Its a ceramic and off/on type of clutch...no give.
As long you are at the 700rwhp or less I think most are running the RST which is a organic dual disc.
The other thing to consider is a CF driveshaft if you stay with the RXT.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Once I pulley swap I'll be in the 750 range, have an RXT waiting to go in. We will see if it's really the clutch that kills the tranny or the driving style.
alrodri8
Tampa, FL
Anthony
2015 Mustang GT
Like I said... I had mine for almost 20k miles with brutal driving along with daily driven miles intermixed. I still have the RXT with an MT82 with cryo-treated gears. The original MT82 in it had seen over 300 track passes and 26k(18k with the RXT) miles before 3rd gear shredding to pieces which I believe mainly occurred due to oil starvation from not overfilling the trans. So far 3k miles with the build trans at over 750 rwhp, soon I should be making closer to 850whp, we'll see how it holds up.
mustang_guy
United States
it has an engine!
I drove a buddies with a Mantic. He blew up his with an Rxt but runs a Qa1 CF driveshaft, which doesn't shock the drivetrain as much as Aluminum units. He's also a bias ply car. He's had the mantic for about 10k now and hundreds of passes at the track. His car runs a Procharger f1a94 dialed on the lowest boost pulley currently. Personally the Mantic feels better over his Rxt.
How many of you with the aluminum driveshaft are usong radials instead of bias ply? Radials add to drivetrain shock, not just shocking the axles.
alrodri8
Tampa, FL
Anthony
2015 Mustang GT
I drove a buddies with a Mantic. He blew up his with an Rxt but runs a Qa1 CF driveshaft. He's had the mantic for about 10k now. Personally the Mantic feels better over his Rxt.
I'm sure it does, but the Mantic is really pricey.
mustang_guy
United States
it has an engine!
Looking back I didn't make clear, per my suggestion he switched to Mantic, slicks and a CF shaft after using an aluminum unit and radials with the Rxt. For the time being he swapped in another stock mt82 and eventually swapping in a built tr6060 after he builds his engine.
dubster99
Nor*Cal
That's what I like to hear. And yes, the mantic is expensive compared to the RXT. I picked mine up on the cheap from someone who ended up not putting it in. Just waiting for the stocker to start to slip.
sandeale
North Carolina
2015 GT Premium PP
After killing 3rd gear in mine (clutch went in the car Nov 16..3rd gear left the building middle of June 17)...i spoke with ben calimer and went with his recommendation of the Exedy stage 3 with a warranty rebuilt trans...no special parts used
