Rxt hd sprunghub!
Blackmamba1989
Canada
2015 mustang
Does anyone use a rxthd sprunghub?
I am debating on installing on a prochrged 2015 mustang with magnum swap.
xr4x4ti
Minnesota
Tim
AWD 2017 Mustang GT 6MT Supercharged.
I have one in my Turbo SBF car. It works fine. I am NOT a fan of non sprung hub clutches. I had Mcleod make me a one off sprung hub version. It is basically the GT500 version mated to a small block ford flywheel.
If you can fit it with the Magnum XL (you can), I would go that direction vs the solid hub.
my $.02.
Tim
Blackmamba1989
Canada
2015 mustang
I did install it on my car and it does work good. There is no chatter at all.
Did your clutch discs and pressure plate come assembled as well?
xr4x4ti
Minnesota
Tim
Yes, they came assembled and marked to ensure that they stayed in balance.
Tim
Blackmamba1989
Canada
2015 mustang
Mine came assembled with instructions "DO NOT DISSASEMBLE!"
But I got a notchy feeling when the clutch is halfway up only when it's running and a slight vibration around 4k rpm
