NoahsArk117
Hey Everyone,
So my car is making this whirring sound, kind of like dry gears rotating, or like a steel marble rolling on a surface. It's coming from under the shifter and is directly tied to throttle input (goes away when off the gas). Its loudest between 2.5k rpm and 4k rpm. Aything over that and the exhaust begins to drown everything out. Its the most apparent when cruising in 3rd 4th and 5th. I had the clutch system (clutch, pressure plate, flywheel, Throw out bearing, Pilot bearing) replaced by Ford about 9 months ago and have only put 6,0000 miles on the car since. I put BG sychromesh fluid in the trans about 1 month ago but the sound started two days ago so I don't think it's related. I've just about had it with this transmission so I'm inclined to ignore it. My main gripe is that I'm out of powertrain warranty so even if it's a defective clutch system part Ford wont cover it even though the whole system was replaced less than a year ago. Anyone have any ideas of what this sound could be?
Thanks
Thanks
