Motor Mounts and possible issues moving forward..
HISSMAN
Large Member
West Virginia
2016 Oxford White GT/PP Premium
I will be installing my Steeda adjustable motor mounts either tonight or tomorrow. I think I am going to do the full 3/4 inch drop that they can provide. Moving forward does anyone have any experience with these, and would this cause an issue with the installation of long tube headers? Also, and tips for doing the swap will be appreciated.
[MENTION=25806]SteedaTech[/MENTION]
Thanks!
-Jeff
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
All cars are different.
There is a very good chance that dropping it 3/4" will cause clearance issues. So just make sure to check clearance all around the oil pan / rack....and the steering rack to header tubes.
HISSMAN
HISSMAN
Large Member
West Virginia
Awesome! That is what I wanted to hear. I may just go 1/2 inch then. Thanks!
[MENTION=9985]BMR Tech[/MENTION]
-Jeff
BMR Tech
Tampa, FL
Dion
No problem. We have done a lot of testing with various engine heights and have found some cars will allow for more drop than others, etc.
Usually you are safe with .500"
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
@SteedaTech
Thanks!
-Jeff
No issues, with going 3/4 of a inch lower, with Kook's or Stainless Steel works headers.
Replace one mount at a time. Plus, make sure you have clearance on the steering shaft to EPAS
When done recheck to make sure you have clearance between engine component's and chassis.
Also, you can reach out to any of our five ASE certified and development Techs with further questions @954-960-0774
Thank you,
Steeda Tech
HISSMAN
HISSMAN
Large Member
West Virginia
Thank you,
Steeda Tech
Thanks also!
09jsw
East coast
2015 Guard PP GT
Wouldn't lowering the engine cause the driveshaft pinion angle to be off ?
terryz
SF, CA
2016 Mustang GT base manual
What's Ford's rationale for placing the engine so high?
HISSMAN
HISSMAN
Large Member
West Virginia
Ease of assembly with the chassis.
