BMR Suspension Releases New Product - Motor Mounts for 05-Newer Mustangs - MM007
BMR Suspension
Seffner, FL
2015 300A PP GT
2005 and Newer Mustang Polyurethane Motor Mounts
MM007
Reduce engine movement and improve throttle response on your 2005 and newer Mustang with Polyurethane Motor Mounts from BMR Suspension. The factory mounts are designed to absorb noise and vibration for a smooth ride, but do little for performance. The BMR mounts are constructed from ÂĽ-inch, laser cut steel plate, aircraft-grade 6061-T6 billet aluminum, and 95-durometer polyurethane bushings. The BMR Polyurethane Motor Mounts (PN MM007) drastically decrease engine movement by replacing the soft rubber bushings with stiffer polyurethane bushings with little change in NVH. These mounts are also 50-percent lighter than factory mounts. Installation time is 2-3 hours. Available in black hammertone powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
Autocratic
Dallas, Tx
2015 Mustang GT
Realistically, how much more NVH will this put into the cabin?
Sent from my Nexus 6P using Tapatalk
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
I'm guessing 3/4" drop max for the s550
BMR Tech
Tampa, FL
Dion
Just wanted to update this post and thank everyone for your support!
These engine mounts were released at $169.95 initially, and have been so popular that we have been able to cut serious costs down - so the current price point is $139.95!
One of our strategies at BMR is to pass our savings on to the end user when we are able to build larger batches and drive costs down.
These pieces help eliminate drive-line twist, offer hood clearance if needed, and save a large % of weight compared to the factory mounts. ;)
