Morning Brakes start up
hchf1234
Florida Fort Myers
Lucas
2020 Mustang gt 10 speed
so i noticed that whenever i go to start my car the brake is hard to push down is this normal or not it’s a 2020 mustang gt base automatic with 26k miles if not what should i do
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Not normal. If it's still in warranty take it to a dealer. Best case is a vacuum leak, worst is a bad booster.
K4fxd
NKY
The booster should hold vacuum for several days to weeks. If the brake pedal is hard when you try to start the car in the AM, something is wrong.
hchf1234
Florida Fort Myers
Lucas
how would i check for a leak
K4fxd
NKY
If the brake pedal is hard when you first push on it in the morning, you have a leak. I'd check the check valve first.
Garfy
Utah
Gary
2020 Mustang GT, 2012 Honda Fit Sport
I have a base GT same as yours and after 5 days of sitting, the brake pedal is hard to depress because the vacuum is gone. That's normal. Now, if you told me yours is a DD and every morning it's hard to depress, then the vacuum check valve is probably leaking and if it's not replaceable, you'd have to replace the entire booster assembly. Depending when you bought it, you could still be under the 3yr/30K miles base warranty so if you're having the problem every morning, take it in for warranty. I don't have a problem with mine if I start it every 3 days, but at 5 days the vacuum assist is gone so it's hard to depress the brake pedal but it's enough to trip the brake switch so you can start the engine.
