Does the smaller diameter cause any problems?The spare tire is a 155/60/18 = 25.3" x 6.1", which does fit in the well.
My tire diameter is 27", so the spare is 1.7" shy of matching.
I have both the spare and the kit so that I have options.
Can anybody report on how the PP aftermarket kit fits?
The OEM spare tire kit with the jack. They are regularly sold by dealerships for $220-230 on eBay. You have a PP, so you would need a spacer, I believe, to get it to work on your front brakes. I was reading some thread a few days ago and apparently some company sells a spare made for the 15" brakes that fits in the spare tire well. Can't remember the outlet though..What did you find on Ebay for $225?
I'm looking for a spare tire option for my 18GT/PP
You should be able to use the OEM spare since you don't have the 15" brakes. Hop on ebay and search for "mustang spare tire kit." First result should be the factory Ford spare with the jack and instructions.I want a spare tire for my 2018 Ecoboost PP. Can anyone make a good recommendation? Ideally, I’d like it to fit in the wheel well and not stick up. Thanks.
I was going to ask if using it on the rear would cause problems since the Ecoboost PP has the Torsen rear end. But I just found another message thread https://www.mustang6g.com/forums/showthread.php?t=40727where someone contacted Torsen and they said using the mini spare wouldn’t hurt as long as they stayed within the limits of the spare. Thanks.You should be able to use the OEM spare since you don't have the 15" brakes. Hop on ebay and search for "mustang spare tire kit." First result should be the factory Ford spare with the jack and instructions.
In general for limited slip rears, the difference in diameters causes premature wear of the frictions. The more you drive on different size tires, the worse it is.Does the smaller diameter cause any problems?
This one does, and it works for us PP guys too. Not the cheapest...And will the spare tire that matches rear tire diameter fit in the spare tire well of the trunk?
Only if it was optioned.Did any s550's come with a spare? I am wondering if it's worth it to check the junk yard.
I don't need the jack or wrench.
