Misfire codes P0300 and P0308
Mcgyver
Sydney
Mark
Mustang GT Magnetic 6 Spd Manual
If you have misfire codes on your S550 (‘15 to ‘17) Mustang GT please be aware that the intake manifolds on these cars are prone to failure in the low speed flaps inside the manifold(Manifold Intake Runner Control). The flaps are controlled by vaccum actuators at the rear of the manifold via two skinny square metal shafts. The shafts are prone to snap where they connect to the actuators. These things are ECU controlled and are constantly fluttering about.
Standard Ford diagnosis for these misfire codes is to replace all plugs, coils and injectors before they will even consider checking the manifold. This will cost over $6k before they even get to the problem. (Which is why many refer to them as Stealerships)
The manifold is quite simple to remove yourself whith the only real difficulty coming in removing the electrical connectors on the actuators and the panel pins that hold the cabling to the manifold. I used a set of panel pop pliers. A new manifold is $1,500 and is easy to install. I am now going to Ford for a warranty claim as there is no way such a part should be a wear item on any car.
There is a handy tutorial on YouTube my VPM which shows all steps in detail except of course the difficult bit behind the manifold. (Funny that eh?)
Fell free to contact me if you want any more information.
SLW5.0
Johnstown, CO
2017 GT Premium w/PP
hi! so I have these codes, ended up replacing the spark plugs myself just to check but the codes came back. do you happen to know of a way to test if the IMRC flaps are working correctly without taking the intake manifold off? i saw somewhere that there was a way to do it but i couldn't find details on how.
NGOT8R
Adrian
2019 Bullitt
I just had those same two codes pop up, along with P0316, after installing some aftermarket upstream o2 sensors. I ended up ordering new OEM sensors which should be here on Friday. FYI, I am running an IMRC lockout kit and had them turned off in my tune.
Mcgyver
Sydney
Mark
Even If you have a good boroscope you would not be able to see whether the shaft were sheared off I don't think..
the removal of the manifold is relatively easy though.
Mcgyver
Sydney
Mark
How did you go SLO5.0?
SLW5.0
Johnstown, CO
Ah, we'll find out Thursday. I work from home and haven't been driving much at all and, since I work on it with my dad, he wasn't free til then. But at least I got my intake in which was a big win. When I ordered it Ford said it was on backorder and they didn't know how long it would take.
SLW5.0
Johnstown, CO
Happy to report it's fixed!! It was definitely the IMRC. A lot of learning along the way lol but I'm glad it's done. Did you have any luck submitting the warranty claim to Ford?
Also, in case anyone else sees this. I bought my IM through Ford's online part website: https://parts.ford.com/
It ended up being cheaper to buy through there and then picking up at my local dealer than trying to order at the dealer directly. Also shop through the various dealers in your area since the price changes. I think I ended up paying right under $500 for mine.
Mcgyver
Sydney
Mark
No bueno with Ford Warranty!
Good to hear you got a result.
