Vlad Soare
- Jan 21, 2020
- Bucharest, Romania
- Vlad
- 2020 Mustang GT 6MT
Hi,
If you have a clutch-type limited slip diff and want to know if the clutches are still good or are in need of a replacement, you can measure the breakaway torque by raising one rear wheel, shifter in neutral, handbrake off, and rotating the wheel with a beam-type torque wrench. But using the torque wrench on a wheel nut wouldn't be too accurate, since the point where you applied the torque wouldn't coincide with the one where you actually wanted to measure it (i.e. center of the wheel). I believe there are tools made specifically for this purpose, to allow you to attach a torque wrench to the wheel in such a way that it is concentric with the wheel. But I don't know how they are called and how they look like, so I don't know how to search for them. Do you happen to know where I could find something like this? Or at least how it's called, and I will take it from there. "Breakaway torque measuring tool", or combinations of words to that effect, didn't seem to return any meaningful results.
Thank you.
Thank you.
